Ebun.1
Senior
November 9, 2021
I want to change the screen with a timer
Thank you for helping.
I want to move to a certain screen when the timer times out.
What kind of implementation should I do?
Thank you.
MM..1
MM..1Best answer
Standart is create dummy transition in designer and in code call it for example
void Screen2View::handleTickEvent() {
	if (tickCounter++ > MENU_TIMEOUT) {
		application().gotoScreen8ScreenCoverTransitionWest();
MM..1
MM..1Best answer
Ebun.1
Ebun.1Author
Senior
November 9, 2021
Hi MM ..1
Thank you for your professor.
It was realized by the following implementation.
XXXXX: View name
application().gotoXXXXXScreenNoTransition();
