KM L.1
I need an example code to operate qwerty keypad using joystick which is available on stm32h743 eval board... Please anyone help me out in this.. I'm struggling from many days ...... Thank u
KM L.1
KM L.1Author
As I'm working on STM32CubeIDE , can I integrate stm32 HAL function with the c++ touchGFX code?
Martin KJELDSEN
Principal III
June 10, 2020
Okay, if you're new to C++ it may be a bit tricky, i don't know. Here are the general steps:
1) Either sample the buttons directly in Model::tick() function (this function is driven by your display timings, typically) ~every 16ms
2) Sample in a different task (in your OS of choice, FreeRTOS is the default from CubeMX) and send that message through a queue which is polled in Model::tick()
3) Interrupt based
The article describes how to make the button act as a trigger in the designer (For instance, when JOY_UP pressed, switch screen), but you don't necessarily need that
I would start by calling your HAL functions directly in Model::tick() to get a feel for how things work. And read this:
https://support.touchgfx.com/docs/development/ui-development/touchgfx-engine-features/backend-communication/#transmitting-data-from-ui-to-surrounding-system
/Martin
KM L.1
KM L.1Author
okay I will look into this..
KM L.1
KM L.1Author
Hi Martin,.
By looking into your webinar I created task for hardware integration but after that nothing is displaying on the LCD ... So what may be the issue?
KM L.1
KM L.1Author
Now able to react to the button pressed .
Now how to make the keyboard to react to the buttons?
KM L.1
KM L.1Author
Please anyone support in this as i'm new to this​
Martin KJELDSEN
Principal III
August 10, 2020
Back from vacation. Did you get any further?
KM L.1
KM L.1Author
Yes one of your team membrane helped me out and its working fine with the joystick.
Thank you:smiling_face_with_smiling_eyes:
Martin KJELDSEN
Principal III
August 10, 2020
Perfect :)
