Hicss.2033
I'm trying to use touchGFX 4.10.0 on a STM32F429I discovery. I'm a new user, so, apart the class refernce manual in STM32cube F4, is there any simple tutorial or getting started guide so I can understand how to move in this environment? Thanks
Also some sample code, just to start, may be useful for unserstanding events and how to connect events to the microcontroller state.
MM..1
Examples is in designer start window and latest is 4.16.1
Hicss.2033
Thanks for your answer.
Where can I find the designer start windows? I'm using system workbench which, for what I undestood, is compatible only with 4.10.0.
Alexandre RENOUX
May 3, 2021
Hello Hicsss.2033,
Like MM..1 mentioned, please use TouchGFX 4.16.1 with TouchGFX Designer. You will have many examples and demos.
Also I highly recommend you to read the documentation website.
When your question is answered, please close this topic by choosing Select as Best.
/Alexandre
Hicss.2033
I'm using system workbench and, for what I have inderstood, it works only with the version 4.10.0. Do the examples that you are citing work also for 4.10.0?
