Luke3
Oct 21, 2019 8:48 AM UTC
I'm trying to integrate touchgfx 4.10.0 to the STM32H743 based board.
Dears, I'm a newbie to the stm32 & touchgfx.
Is there anyone who has experienced in initializing environment with cubemx & STM32H743?
I couldn't find any graphics options for STM32H series at the cubemx 5.4.0 and any reference in this site. Any help would be really appreciated!
Martin KJELDSEN
Principal III
Oct 21, 2019 9:05 AM UTC
Hi, there's no H7 support for TouchgFX in CubeMX currently. You can base your applications on the H743 template we have available from the TouchGFX designer. Try it out.
/Martin
Luke3
Luke3Author
Oct 21, 2019 9:23 AM UTC
Dear Martine,
thank you so much for your so quick response!
Luke3
Luke3Author
Oct 21, 2019 9:36 AM UTC
Dear Martine,
I'm sorry I can't understand the workflow well. Could you please explain detailed steps to utilize generated code from the TouchGFX designer?
Martin KJELDSEN
Principal III
Oct 21, 2019 11:44 AM UTC
No problem! Just go into the designer and create a new application. You'll have the option to select an "Application template" which represents the board and a "UI template" which can be blank or you can load one of the examples/demos we have available.
From application templates you'll be able to choose H743-EVAL. Let me know.
/Martin
Luke3
Luke3Author
Oct 22, 2019 7:10 AM UTC
Dear Martin,
Thank you for your detailed explanation.
I could utilize template BSP/HAL source tree from the designer.
The source tree looks slightly different from that of "STM32Cube_FW_H7_V1.5.0".
I expect it will work nicely!
Thanks,
Luke
Luke3
Luke3Author
Oct 23, 2019 2:25 AM UTC
Dear Martin,
Thank you for your information.
Does the ST have any plan to support touchgfx option for the cubemx H7 series?
Thanks a lot!
