Ebun.1
Senior
Jun 2, 2020 3:54 AM UTC
I get an error just creating a new project
environment
TouchGFX4.12.3
Select STM32F746G Discovery Kit in APPLICATION TEMPLATE
Select Blank UI in UI TEMPLATE and create
Creation of TouchGFX Application failed.
Why?
How can I check the error log?
Thank you.
Jagdish Bisawa
Jagdish BisawaBest answer
Jun 2, 2020 6:38 AM UTC
Hi @Ebun.1​ ,
I have been using TouchGFX Designer V 4.13.0 & have not come across such an issue. This version has a button on the bottom right that can display the log of activities.
May be you can try to upgrade to the latest version & do away with this proble.
/Jagdish Bisawa
Jagdish Bisawa
Hi @Ebun.1​ ,
/Jagdish Bisawa
Ebun.1
Ebun.1Author
Senior
Jun 2, 2020 7:01 AM UTC
Hi Jagdish Bisawa
Thank you for your reply.
Certainly, there was no problem with Ver4.13.0.
