Dec 22, 2025 7:21 AM UTC
I created a button with TouchGFX, but the response to the button click is slow
Edited by a ST moderator: Please use English language in this community. Thank you
ボードは、STM32F746G_DISCOを使用しています。タッチTouchGFXデザイナーにて、データ増減用のボタンを作成し、ボタンクリックでデータを増減する様なソフトウェアを構築しましたが、ボタンクリックに対して反応が遅い現象が出ています。ボタンのクリックに対して、GUI上のボタンは、反応していますが、ソフトウェア上の処理がなされない事が多い現象が出ています。どの様な原因が考えられるでしょうか?お教えください。よろしくお願いいたします。
Translation:
I am using the STM32F746G_DISCO board. I created buttons for increasing and decreasing data using TouchGFX Designer, and built software that increases and decreases data with button clicks. However, I am experiencing a slow response to button clicks. The buttons on the GUI respond to button clicks, but the software often fails to process them. What could be the cause of this? Please let me know. Thank you in advance.
    Jan 2, 2026 12:46 PM UTC
    Hello @ベル_it.
    It is a bit difficult to help you based on the very brief description. Can you share the project or alternatively relevant code snippets?
    Are you using the TouchGFX Board Setup for STM32F746G Disco available in TouchGFX Designer? Does the project work as intended when running the simulator?
    Best regards,
    Johan
    Jan 23, 2026 9:28 AM UTC
    Hello @ベル_it.
    Have you been able to make any progress?
    Best regards,
    Johan
