Fadi.Albaghdadi
I cannot create any project or run simulator or generate cod
  • February 7, 2021
  • 5 replies
  • 1091 views
Generate Code
  Generate
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j10
    The system cannot find the path specified.
    'B' is not recognized as an internal or external command,
    operable program or batch file.
    Failed
  Failed
Romain DIELEMAN
Could you share the path of your project ? Are there any space or "uncommon" characters somewhere ?
Could you also specify the version of TouchGFX you are using ? Are you creating a project with an application template for a specific board or a UI template ?
/Romain
Fadi.Albaghdadi
Thank you very much. You can log in to my computer and see the problem anydesk
I am using a blank project in addition I also tried with a template
I find the same problem
email: fadi.albaghdade@gmail.com
Romain DIELEMAN
I know there has been people facing similar issues with Turkish language settings on their computer, I cannot remember the exact reason but it was due to some characters not recognized in the folder path of the projects. Please try creating a project directly in the /C folder or in /C/TouchGFXProject. I'll try to find the previous posts of people facing the same issue
/Romain
