ALABSTM
ALABSTMBest answer
Apr 22, 2022 9:12 AM UTC
Hi @KHuan.8​,
Indeed, we are experiencing issues with the link you mentioned and a couple of other ones since a few time. We do apologize for any inconvenience caused.
As a solution, you can use CubeMX to download the firmware package of your choice with, inside, the desired version of the STemWin library. Please find more details here.
I hope this helps. Do not hesitate, should you face any problem.
With regards,
Amel NASRI
Apr 21, 2022 2:35 PM UTC
Hi @KHuan.8​ ,
You should be able to download STemWIN from STemWin - Professional graphical stack library enabling the building up of Graphical User Interfaces (GUIs) (AN4323) - STMicroelectronics.
Do you confirm that it works properly or there is an issue?
I add @ALABB​ in the loop to fix the link in GitHub side.
-Amel
KHuan.8
KHuan.8Author
Apr 22, 2022 1:04 AM UTC
Hi @Amel NASRI​ ,
Thanks very much for your information, the link you provided is worked and I can download the STemWin , but the version is 5.32 which is different with the GitHub mention as 5.44.40, I am not sure which one is correct?
ALABSTM
ALABSTMBest answer
Hi @KHuan.8​,
With regards,
KHuan.8
KHuan.8Author
May 2, 2022 2:07 AM UTC
Hi @ALABB​ ,
Thanks very much to answer my question, I can use the library now.
Please close this ticket, thanks again.
ALABSTM
May 4, 2022 10:31 AM UTC
Hi @KHuan.8​,
Really glad to read your reply. I let @Amel NASRI​ close this thread.
With regards,
Amel NASRI
May 4, 2022 12:11 PM UTC
Thanks @KHuan.8​ & @ALABB​ for the follow-up.
In our community, a question is closed when a Best Answer is selected.
This is what I did selecting @ALABB​ 's answer.
-Amel
