MLync.1
Feb 3, 2020 1:40 AM UTC
I am using a touchgfx scrollable container to create a list. I include a radio button in the container. My problem is: In the container the radio button is assigned to radioButtonGroup1.
When I select the radio button for a list element, the other list element radio buttons are not deselected. Is there a way to make the radiobuttongroup for all of the list elements the same?
Alexandre RENOUX
Feb 18, 2020 12:56 PM UTC
I don't understand completely the question. You include only one radio button in the scrollable container and the other radio buttons are outside this scrollable container ?
Could you elaborate on your problem so that I can have a better understanding and give a correct answer ?
If you can attach a screenshot of your actual UI setup, this would be a plus.
/Alexandre
