How to work with pixels?
Hello!
I put to project a widget box1, it's color is white.
I want to set color of each pixel of box
like this: SetPixel(x,y, R,G,B);
And after I want to read color of pixel? like this: color=GetPixel(x,y);
How can I do it in TouchGFX?
Alexandre RENOUX
December 14, 2020
There's not such feature for the box widget.
If you want to change each pixel on the screen, one way would be to retrieve the pointer of the framebuffer and write directly the values you need.
You can retrieve the framebuffer pointer by calling lockFramebuffer() (see link)
/Alexandre
December 14, 2020
No... working with buffer is not good idea.
I want to change pixel on coordinates X,Y of widget, and then I want to move widget to new coordinates. What widget can I get, to draw on it's (widget's) canvas?
