M3R
how to use two callback in screenViewBase::screenViewBase() ?
  • August 26, 2020
  • 3 replies
  • 1121 views
hello
i want to used clicklistener and button callback.
how to wrote this two callback in screenViewBase?
screenViewBase::screenViewBase() :
	buttonCallback(this, &screenViewBase::buttonCallbackHandler)
	boxClickedCallback(this, &screenViewBase::boxClickHandler)
like this
i'm new in c++ language
Best answer by JPeča.1
Hi, I do not know if it right way, but I did it like this:
Screen1View::Screen1View():imageFadeAnimationEndedCallback(this, &Screen1View::imageFadeAnimationEndedHandler),
image2FadeAnimationEndedCallback(this, &Screen1View::image2FadeAnimationEndedHandler),
image3FadeAnimationEndedCallback(this, &Screen1View::image3FadeAnimationEndedHandler)
Best regards.
Jan
JPeča.1
JPeča.1Best answer
Best regards.
Jan
M3R
M3RAuthor
Yes,Thanks a lot JPe�?a.1.
Alexandre RENOUX
August 27, 2020
Yes what @Jan Pe�?a​ said is correct.
Also, never try to modify ScreenViewBase. It's a file generated by TouchGFX so all your modifications will be overwritten when you regenerate code.
The file that can be edited by the user is ScreenView as mentioned for the solution.
/Alexandre
