NDura.16
How to update values of custom containers at TouchGFX?
I created custom container for spesific purpose and I want to see USB connection status there. Therefore, I have to update the value of status continuously. Custom containers does not have presenter.cpp file and I do not refresh the value simultaneously.
Thanks.
AndrewM
If I understand you correctly, you'd like to be able to access the presenter pointer from within a custom container that belongs to the relevant view class?
I use this technique a lot. Basically in your custom container you just need a data member of type 'pointer to Presenter' and a function to set the data member eg
// in eg UsbContainer.hpp
class UsbContainer : public UsbContainerBase
public:
 void setPresenter(MyPresenter* presenter)
 presenter_ = presenter;
 void display()
 int state = presenter_->getUsbState();
 show(state);
protected:
 MyPresenter* presenter_{nullptr};
// in eg MyView.cpp
void MyView::setupScreen()
 MyViewBase::setupScreen();
 usbContainer.setPresenter(presenter);
 usbContainer.display();
