JPabl.1
Oct 24, 2024 9:54 PM UTC
how to trigger modal in all screens from the model
Hi there Touchgfx team!
I have about 15 different screens. I also have a modal that says "battery critical level". I know how to propagate a notification from the model to the view to trigger this modal.
My question is: is there an easy way to do this for 15 different screens? or everytime I need to override the notification function in each screen?
Thanks a lot in advance
ferro
ferroBest answer
Lead
Oct 31, 2024 9:56 AM UTC
@JPabl.1  Ah, sorry...forgot assets are also a must. try this one.
ferro
Lead
Oct 25, 2024 7:53 AM UTC
Hi @JPabl.1 , one solution could be a new screen, just with that warning message window and transparent background and transition to that. Then back to original screen.
JPabl.1
JPabl.1Author
Oct 25, 2024 5:24 PM UTC
Hi @ferro , thanks for the reply.
I think that might work if the modal were just a single screen, but the UI requirements is for it to pop up on top of the current screen, like this:
From your answer it seems the only way will be to the same on all screens?
ferro
Lead
Oct 25, 2024 8:01 PM UTC
Hi @JPabl.1
Yes, and that is exactly what will happen. But I forgot one important detail.
Before transitioning to the warning screen, You must set the size of the default background box, named __background, injected automatically by Gfx Designer ( I suppose you use screen Base clasess) to the size of your modal widget. In that case, the previous screen content stays as it is ( in frame buffers).
If you could rephrase that please, do not inderstand what you mean.
I've just remembered this post
https://community.st.com/t5/stm32-mcus-touchgfx-and-gui/persistent-widgets-between-screens/m-p/690918
JPabl.1
JPabl.1Author
Oct 30, 2024 4:18 PM UTC
How can I run that project? I get :
ferro
ferroBest answer
Lead
JPabl.1
JPabl.1Author
Oct 31, 2024 5:54 PM UTC
That will do the trick, thanks a lot!
