SKS.2
How to Send String Message TO TFT LCD using STM32F429XXX Microcontroller without using any Library Function. Need Bear Metal code for the Same
waclawek.jan
Well, if you don't have a library, you have to write your own. Strings constists of letters, and those consists of dots (pixels). Start with displaying a dot (or "clearing" the whole screen by writing many dots of the same color). That requires to cope with the communication with the display. That requires to read/understand the display's datasheet/manual, and to read/understand the connection between STM32 and the display.
SKS.2
SKS.2Author
I need Assistant to Display Any string on the LCD, I have done most of the coding part but need to send that string , From Datasheet I m not getting how do that
