KMili
May 29, 2019 10:47 AM UTC
How to send messages to Touchgfx simulator app?
I need to simulate some external data while running simulator. For example, our device reads temperatures and I need some way to pass those temperatures (simulate) to simulator. Is there any way that is ready for this? Or I must write WinAPI code for that (sockets, COM, IPC, etc.)?
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
May 29, 2019 11:11 AM UTC
Hi @KMili​,
There are a few ways to go about it. If you have a complex simulator application, yes, you can create a standalone simulator and just communicate with the TouchGFX Simulator using sockets (Check for socket data in Model::tick() ). We've done this in the past for customers - It's a very flexible solution.
Or, if you want to embed the simulated data inside the simulator application you can use FrontEndApplication to react to keyboard events to trigger various scenarios.
Edit (Adding text from other post): Override the handleKeyEvent() method in your FrontEndApplication class.
void FrontendApplication::handleKeyEvent(uint8_t c)
 //Pass the keyevent on
 touchgfx::MVPApplication::handleKeyEvent(c);
 //Handle events
 if (c == '1')
 model.startSimulation();
 return;
Let me know what you think
/Martin
Martin KJELDSEN
Principal III
Hi @KMili​,
 //Handle events
 if (c == '1')
 return;
/Martin
KMili
KMiliAuthor
May 29, 2019 11:23 AM UTC
"you can use FrontEndApplication to react to keyboard events" - how to do that?
