JJ.Lin
How to reverse the LCD display up down by configuring LTDC or DMA2D regester
How to reverse the LCD display up down by configuring LTDC or DMA2D regester? Is it feasible?
/JJ.Lin
waclawek.jan
No.
MSale.1
Senior
July 6, 2021
@Community member​
You really dont like the DMA2D cause of this limitation and i too:face_with_tears_of_joy:. it really should be able to rotate
Hello @JJ.Lin​ ,
Do you mean Layer position configuration ?
You can have a look at this AN4861, this may help you on the configuration, as contains an example of LTDC layer parameters configuration using STM32CubeMX..
Imen
July 6, 2021
I think the question relates to mapping the frame buffer backward, presumably because it is easier to flip that than orientate the display correctly for the application. Pretty sure all the painting and drawing code could be flipped, it's more about the HW abilities/limitations.
So perhaps DMA with memory address decrementing rather than incrementing.
waclawek.jan
You mean, utilizing MDMA? That might be viable, but only in the 'H7.
