ALuiz.1
May 19, 2022 10:42 PM UTC
How to print no string?
I'm using a container with a text area with no wildcard for printing different strings, it works fine with text.setTypedText(TypedText(T_XX)); according to the if value. But sometimes it needs to print no string, something like text.setTypedText(NULL); but I can't do this, it doesn't accept NULL parameter and using wildcard, it prints the previous value of text area. How to clean the text area?
Andrew Neil
May 20, 2022 8:05 AM UTC
What if you just use an empty string - ie, "" ?
Or maybe a string that contains only whitespace?
Osman SOYKURT
May 20, 2022 8:34 AM UTC
Hello ALuiz.1,
I'd go for a solution like Andrew Neil said. Just create a new text empty, and use it in your code.
Don't forget to call the invalidate() function with your textArea widget so that the previous value will be removed and the new one (empty string) will be applied.
/Osman
