AndrewM
Feb 7, 2020 8:00 AM UTC
How to measure memory usage?
I need to measure memory usage in my TouchGFX application. Is there a way to do this?
Ozone
Principal
Feb 7, 2020 8:39 AM UTC
First starting point would be the map file generated by the linker.
Not sure if the TouchGfx vendor supplies some additional evaluation tool for gfx-internal memory consumption.
eng23
Senior
Feb 7, 2020 10:44 AM UTC
Another approach would be starting a project in new version CubeMX 5.5 and enabling all necessary peripherals for touchgfx (ltdc, fmc, freertos) and generate code. After, look in CubeIDE>Build Analyzer the memory usage for ram and flash. So generate code with touchgfx v4.13, through X-CUBE-TOUCHGFX, open touchgfx IDE and generate code there. Now touchgfx is enabled and you can see the new memory usage.
