ARM_and
Jun 20, 2025 4:42 PM UTC
How to limit scroll list frm scroll past the end of the list. Overshoot for the bottom?
We can control the overshoot percentage of a scroll list which seems to limit how much a "pull down" is allowed and animated above the top of the list.
Is there a similar thing for the bottom of the list?
a way to keep the list from being scrolled past the bottom of it as it's happening in the below image? (the list contains 9 elements in total.
GaetanGodart
GaetanGodartBest answer
Jun 23, 2025 2:24 PM UTC
Hello @ARM_and ,
Unfortunately as far as I know, there is no functions to change that.
We are aware of that limitation and are considering changing the implementation.
Regards,
Gaetan GodartSoftware engineer at ST (TouchGFX)
GaetanGodart
Hello @ARM_and ,
Regards,
ARM_and
ARM_andAuthor
Jun 26, 2025 2:02 PM UTC
Thankyou @GaetanGodart .
If you decide not to change the implementation, it would be nice to know if there is some function we can override in our .cpp file and call animateToItem(lastItemIndex - 4, 1) if the newY is out of spec.
-A
