Asantos
Jan 29, 2020 4:51 PM UTC
How to install templates offline?
My office computer only have internet access via virtual machine, So i can't download the templates in the TouchGFX Designer.
How to install the STM32F746G-DISCO template offline?
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Jan 30, 2020 9:10 AM UTC
Place AT package files into app/packages of your designer install. e.g. for mine:
D:\TouchGFX\4.13.0\app\packages
You will have to request them, for now, to get the files. Which ones do you need?
/Martin
HHarj.1
Jan 29, 2020 6:24 PM UTC
USB memory stick?
Asantos
AsantosAuthor
Jan 29, 2020 10:15 PM UTC
My problem is were to download the template files and know in what directories the files should be transferred to.
Martin KJELDSEN
Principal III
/Martin
Asantos
AsantosAuthor
Jan 30, 2020 11:48 AM UTC
Martin,
I need the last template for the "STM32F746G Discovery Kit".
Another PC with the template installed, in the directory C:\TouchGFX\4.13.0\app\packages, it only have the files:
BlankUI-2.0.0.tpa
Simulator-2.0.0.tpa
Martin KJELDSEN
Principal III
Jan 30, 2020 12:09 PM UTC
The two templates that you're referring to are simply the two default packages that the designer comes installed with.
The actual packages you've downloaded are inside %APPDATA%/Touchgfx-4.13.0/Downloads
Martin KJELDSEN
Principal III
