PChil.1
May 12, 2020 5:46 PM UTC
How to Import Widgets
I am working on a project that I would like to import a keyboard into, like the one in the examples. How do I import widgets into projects?
Karan 123
Karan 123Best answer
Senior
May 12, 2020 6:28 PM UTC
Please check below link.
https://www.youtube.com/watch?v=uE6eiTjOP-g&t=1251s
Hope this helps.
Karan
Karan 123
Senior
Hope this helps.
Karan
PChil.1
PChil.1Author
May 12, 2020 6:47 PM UTC
I will watch that, thank you.
Martin KJELDSEN
Principal III
May 13, 2020 8:44 AM UTC
There's currently no good way of importing a single widget (it usually consists of both json definition as well as custom code). You can import a complete GUI from another project, but this is not what you want. We're discussing how to best create a reusable widget/screen repository.
/Martin
scottSD
Senior III
May 19, 2020 12:31 PM UTC
@Martin KJELDSEN​ , looking forward to that implementation. A widget/screen repository would alleviate a lot of issues and be very helpful.
Another thing that would be useful is to be able to simply copy/paste widgets (or any Designer elements) from one instance of TouchGFX Designer to another instance of the Designer. The only way to copy/paste currently is from one screen to another in the same instance of TouchGFX Designer.
I have numerous projects that are similar and I would like to do this, but I end up having design it all over again or I copy parts of the JSON code and other files with a difference/merge tool.
Martin KJELDSEN
Principal III
May 20, 2020 8:15 AM UTC
Would you expect the custom code for that widget (e.g. Custom Container) to be copied with the gui definition?
PChil.1
PChil.1Author
May 13, 2020 1:37 PM UTC
Thank you for your answers!
Martin KJELDSEN
Principal III
No problem!
