Aug 23, 2023 3:09 PM UTC
How to hide the "painter" for circleprogress widget
I want to hide the colored progress bar in circleprogress widget when there is no data. I can hide the whole widget but how can I keep the background image(a grey circle) in place. If i set the value to 0 there is still a small dot that remains. I assume the item name is:
circleProgress[Your widget name]Painter
But there is no visibility setting for that.
JTP1Best answer
Graduate II
Aug 23, 2023 5:29 PM UTC
Hello
Set image with background png behind the circleProgres. When you hide circleProgress, the image is seen.
Or maybe set painter color same as background circle color when want to hide it (if you use solid cirlce in background image).
(Hope somebody gives you better solutions :D)
Br. J.T
JTP1Best answer
Graduate II
Hello
Br. J.T
tarmogrAuthor
Aug 24, 2023 5:48 AM UTC
thanks, used your first solution. TouchGFX seems efficient enough not to include the same image twice. Wether id draws the same image on top of eachother multiple times that i dont know, so maybe there is additional CPU time overhead because of this. Would it make any sense to hide the background image when displaying the circleprogress?
Graduate II
Aug 24, 2023 7:17 AM UTC
Hello.
Good that it helped. Yes it makes sense to set other object not-visible when not needed. It might save same cpu time.
Br J.T
