Osman SOYKURT
Osman SOYKURTBest answer
Oct 19, 2026 2:57 PM UTC
Hello ​@redstone8415 ,
Have you tried setting a breakpoint inside your model ? for instance in void Model::tick()
​@Andrew Neil  has a point: you may have optimizations enabled, so the debugger can't get the values. Try building with -O0.
Andrew Neil
Oct 13, 2026 9:22 AM UTC
You need to give some more detail on your setup and what, exactly, you’re doing:
But common reasons for such errors are
  • The variable in question is currently out-of-scope
  • The variable in question has been optimised-out
Osman SOYKURT
