Senior III
May 13, 2026 8:17 AM UTC
How to get click event type from flexButton callback
I have a flexButton in a View, and I want to execute different functions depending on whether the button is PRESSED, RELEASED, or CANCEL.
I know you can create interaction in TouchGFX Designer, but you can only call a virtual function on click. Is there a way to, for instance, enable the clickListener Mixin to read the event that has fired the callback from that specific button?
I need to read this event within the view and relative to my button.
Is there a way, or do I have to create a custom widget?
nico23Best answer
Senior III
May 13, 2026 12:59 PM UTC
Ok, following this doc and using const touchgfx::ImageButtonStyle< touchgfx::ClickButtonTrigger >& button instead of const Box& b worked
nico23AuthorBest answer
Senior III
