jsalg.1
Feb 27, 2024 8:54 AM UTC
how to get a tpa version?
I am working on custom display board. created project using touchGFX I would like to know to how to confirm what is the tpa version touchGfx used to create this project.
any interface to get tpa version or BOM file which includes all package version. ?
Smartembedded
SmartembeddedBest answer
Feb 28, 2024 10:37 AM UTC
Hi Jalg.1
Look into your <project>.touchgfx file :
There should be some lines with the info.
"ApplicationTemplateVersion": "4.2.0",
"ApplicationTemplateDescription": "EDT Evaluation kit Application Template",
Osman SOYKURT
Feb 27, 2024 1:15 PM UTC
Hello @jsalg.1 ,
If you started your project from a TouchGFX Designer you should have in your project folder a file called changelog.txt. In this file, we mention all the versions of the tpa (at the release date) and changes between them. Something like this :
In this example, I know that the version of the tpa that I used was version 3.0.4. (The latest as of today is 3.0.7 for this TBS).
If you update your TBS to a newer version of TouchGFX, this file will not update, so you always know the version of the tpa you used when you started your project.
jsalg.1
jsalg.1Author
Feb 28, 2024 4:43 AM UTC
Hi @Osman SOYKURT ,
Thanks for your response, surprisingly, I see no changelog.txt is generated in my project folder. I am using TouchGFX designer version 4.21.0 and created project for EDT board.
Osman SOYKURT
Feb 28, 2024 11:00 AM UTC
Hello @jsalg.1 ,
Partner's TBSs are not made and maintained by us, it could be that this file is not there indeed.
What you can do then is to navigate to your AppData folder (C:\Users\YOUR_USERNAME\AppData\Roaming\TouchGFX-4.21.0) and see which version of the TBS was downloaded by TouchGFX. If you have worked with different TBS versions, it will not tell you which one you have used, but if you have used only one, you will see only one tpa among the different folder (versions) of this TBS.
In this example, for the same TBS, there's only one tpa downloaded and it's version 3.0.17.
I've checked in my 4.21.0 folder and I don't see an EDT TBS. Make sure it's with TouchGFX Designer 4.21.0 that you created your project from.
Smartembedded
Hi Jalg.1
