Jack li1
Feb 19, 2019 4:45 AM UTC
How to draw a line with finger?
Hi,How can i draw a line on my display touchscreen with my finger.I have used Graph widget before,but the coordinate point must be monotone increasing。Could i use the method for QrCode,and could you write an example for this。Thanks�?�?�?
Best regards
Martin KJELDSEN
Principal III
Feb 19, 2019 7:55 AM UTC
Hi @Jack li​,
You could create a custom widget (Like the QrCode) that hooks into the ::draw() method and simply draw into the framebuffer at the relative location of your finger (hook into ::handleClickEvent() and ::handleDragEvent() to get these coordinates. You will not have the antialiasing that the Graph gives you, but you have more freedom here.
Does that make sense?
Best regards,
Martin
Jack li1
Jack li1Author
Feb 22, 2019 7:17 AM UTC
Hello,@Martin KJELDSEN​
Thanks for you help ,but i can understand that .First i can't understand how to use ::draw() method ,maybe on touchgfx.com have Tutorial,l can't find it.so could you tell me through the entire process step by step or how can i do this .
Thank you very much !!!!
Best regards
Jack li
Jack li1
Jack li1Author
Feb 19, 2019 9:01 AM UTC
:beaming_face_with_smiling_eyes:
