SPark.28
Apr 26, 2022 12:29 AM UTC
How to display 14-bit gray pixel data through LTDC module.
I'm testing the 14-bit (or 16-bit) output from ADC to display using LTDC module.
There is L8 mode among LTDC input types, so I checked the ADC output by normalizing it to 8-bit.
But, what i really need is 14-bit (or 16-bit) gray output.
I want to know how to set LTDC to output 14-bit gray data.
MM..1
Apr 26, 2022 5:15 AM UTC
LTDC can send max 24bit data , if you have special display you can show what you mean , but normal gray scale is only 8bit .
