How to detect Release of item of scrolllist ?
I want work with scrolllist this way: touching and dragging -> scrolling the list of files, pressing (without drag) and releasing -> go to directory after releasing.
Question: how can i get Release event? Scrollist has onle 2 events - setItemSelectedCallback and setItemPressedCallback
MM..1
Try read this Workaround for swipe containers not swiping if dragged on a button within (st.com)
Or simpiy you need activate onclicklistener maybe not release
December 20, 2020
Problem.....
If I create more than 9 files - system halts when I scroll list DOWN.
The program halts during the execution of scrollList1UpdateItem() that is called for no apparent reason. is this normal? I don't update the elements, but for some reason when scrolling down scrollList1UpdateItem is called.
Should it be called while scrollin DOWN?
MM..1
scrollList1UpdateItem is called by system on every changes and need be writed as i show, reflect all values in itemIndex.
Please read how scrollist class work in reference ScrollList | TouchGFX Documentation
