EMill
Feb 23, 2023 8:33 AM UTC
How to change size of boxProgress in TouchGfxDesigner 4.21.1?
I would like to change the size of a boxProgress.
But the Width and Height are lock all time.
Thanks for help.
Yoann KLEIN
Feb 23, 2023 9:25 AM UTC
Hello @EMill​,
That is normal, this widget dimensions depend on the preset you are using.
Click on "Preset" on the Properties pane of TouchGFX, after you selected this widget.
You will be able to select different presets there, to choose a bigger or smaller one if you want.
/Yoann
Yoann KLEINST Software Developer | TouchGFX
EMill
EMillAuthor
Feb 25, 2023 12:18 PM UTC
Hello Yoann,
ok, that works fine, but if i want to use my own background, with 'No preset' the width an height are still locked to the last preset size i used.
How can i change the size with 'No preset'?
Edgar
Romain DIELEMAN
Feb 28, 2023 1:16 AM UTC
This widget requires an image as a background, so you can use your own image but you will not be able to change its width or height.
/Romain
EMill
EMillAuthor
Feb 23, 2023 9:34 AM UTC
Hello Yoann,
Edgar
