mchin.1
How to change screen with touchgfx api functions with out interactions?
I am working on touchgfx LCD. I need a a support to develop our custom application.
i have seen touchgfx API functions setup screen but i need example for better understanding.
MM..1
application().gotoXXXXXScreenNoTransition();
mchin.1
mchin.1Author
Thank you but i have seen below information
switchScreen​
virtual void switchScreen(Screen *newScreen)Switch to another Screen.Will call tearDownScreen on current Screen before switching, and subsequently call setupScreen and draw automatically for the new Screen.Parameters:newScreenA pointer to the new screen.
how can i use this to switch from one screen to other
mchin.1
mchin.1Author
I am not getting this gotoScreen5ScreenNoTransition() in application.gotoScreen5ScreenNoTransition(); with out interaction.
I do not want to add interaction so at that time what should i do for screen change ?
MM..1
I dont check 4.18 , but every screen have in application Base generated NoTransition goto. Check it. Interaction dummy you need only for animated transition changes.
mchin.1
mchin.1Author
I am using 4.17.0 Base generated NoTransition goto not generated when add screen only
but generated whenvever adding screen change interaction
MM..1
You check file FrontendApplicationBase.cpp?
mchin.1
mchin.1Author
yes
i checked that file
not generated Base generated NoTransition in FrontendApplicationBase.cpp if i just add screen simply.
so How can i change screen with out this application().gotoXXXXXScreenNoTransition();. finally i got a error.
MM..1
I have only one no empty screen in app no interactions and file in v 4.17
/********** THIS FILE IS GENERATED BY TOUCHGFX DESIGNER, DO NOT MODIFY ***********/
#include <new>
#include <gui_generated/common/FrontendApplicationBase.hpp>
#include <gui/common/FrontendHeap.hpp>
#include <touchgfx/transitions/NoTransition.hpp>
#include <texts/TextKeysAndLanguages.hpp>
#include <touchgfx/Texts.hpp>
#include <touchgfx/hal/HAL.hpp>
#include <platform/driver/lcd/LCD16bpp.hpp>
#include <gui/screen1_screen/Screen1View.hpp>
#include <gui/screen1_screen/Screen1Presenter.hpp>
using namespace touchgfx;
FrontendApplicationBase::FrontendApplicationBase(Model& m, FrontendHeap& heap)
 : touchgfx::MVPApplication(),
 transitionCallback(),
 frontendHeap(heap),
 model(m)
 touchgfx::HAL::getInstance()->setDisplayOrientation(touchgfx::ORIENTATION_LANDSCAPE);
 reinterpret_cast<touchgfx::LCD16bpp&>(touchgfx::HAL::lcd()).enableTextureMapperAll();
 * Screen Transition Declarations
// Screen1
void FrontendApplicationBase::gotoScreen1ScreenNoTransition()
 transitionCallback = touchgfx::Callback<FrontendApplicationBase>(this, &FrontendApplication::gotoScreen1ScreenNoTransitionImpl);
 pendingScreenTransitionCallback = &transitionCallback;
void FrontendApplicationBase::gotoScreen1ScreenNoTransitionImpl()
 touchgfx::makeTransition<Screen1View, Screen1Presenter, touchgfx::NoTransition, Model >(&currentScreen, &currentPresenter, frontendHeap, &currentTransition, &model);
mchin.1
mchin.1Author
i am checking Screen Transition Declarations in FrontendApplicationBase.cpp ..Is it right?
mchin.1
mchin.1Author
#include <new>
#include <gui/screen2_screen/Screen2View.hpp>
#include <gui/screen2_screen/Screen2Presenter.hpp>
#include <gui/screen3_screen/Screen3View.hpp>
#include <gui/screen3_screen/Screen3Presenter.hpp>
#include <gui/screen4_screen/Screen4View.hpp>
#include <gui/screen4_screen/Screen4Presenter.hpp>
#include <gui/screen5_screen/Screen5View.hpp>
#include <gui/screen5_screen/Screen5Presenter.hpp>
#include <gui/screen6_screen/Screen6View.hpp>
#include <gui/screen6_screen/Screen6Presenter.hpp>
#include <gui/screen7_screen/Screen7View.hpp>
#include <gui/screen7_screen/Screen7Presenter.hpp>
#include <gui/screen8_screen/Screen8View.hpp>
#include <gui/screen8_screen/Screen8Presenter.hpp>
#include <gui/screen9_screen/Screen9View.hpp>
#include <gui/screen9_screen/Screen9Presenter.hpp>
#include <gui/screen10_screen/Screen10View.hpp>
#include <gui/screen10_screen/Screen10Presenter.hpp>
   frontendHeap(heap),
   model(m)
  touchgfx::HAL::getInstance()->setDisplayOrientation(touchgfx::ORIENTATION_PORTRAIT);
// Screen1
mchin.1
mchin.1Author
1st screen is ok but for rest of the screens i did not get so how can i change my application from screen1 to screen 2 with out interaction. i need that give me support & concept.
MM..1
OMG yes without interaction you need add this manualy to GUI files as everythink.
FrontendApplication.cpp
#include <gui/common/FrontendApplication.hpp>
FrontendApplication::FrontendApplication(Model& m, FrontendHeap& heap)
 : FrontendApplicationBase(m, heap)
add here screen 2 3 4 ...
void FrontendApplication::gotoScreen2ScreenNoTransition()
 transitionCallback = touchgfx::Callback<FrontendApplicationBase>(this, &FrontendApplication::gotoScreen2ScreenNoTransitionImpl);
void FrontendApplication::gotoScreen2ScreenNoTransitionImpl()
 touchgfx::makeTransition<Screen2View, Screen2Presenter, touchgfx::NoTransition, Model >(&currentScreen, &currentPresenter, frontendHeap, &currentTransition, &model);
and into hpp ...
mchin.1
mchin.1Author
Thank you OK Is It works ? I will tell you after try manual addition.
Please tell about this stuff how to use beacause i am very new
switchScreen​
MM..1
maybe try
application().switchScreen( &Screen2View );
mchin.1
mchin.1Author
Hi
screen changing is working fine.
i have a doubt about buttons.
If i add any button with out interaction how can i know is that button pressed or not?
Is button operation work without button interaction?
MM..1
Mark answer , that help you as best and open new thread for this question out of topic
