kD1
How to bring up DSI display 240x320
Hi STM, we are working on DSI of 240x320 with STM3F769NI Micro controller with our own PCB design. Could you please help us in providing any sample code which have worked with 240x320 display.
September 19, 2020
Get the data sheet for the display, and start with the parameters and expectations then.
Select LTDC and DSI clocks based on requirements established above.
Take the F769I-DISCO LCD code as a model.
kD1
kD1Author
Hi clive, please find attached document which is having design for DSI communication between STM32f769NI controller and 240x320 LCD. Please review the design pins are correct or any corrections to be done.
Regards,
Kishore D
kD1
kD1Author
Thanks for reply clive. I have generated GFX code with IAR IDE 8.40. Code is not hitting breakpoint at screen1 while running task. I have tested by implementing another task, it is hitting second task. why GUI task is not hitting but reaching to frontedapplicationbase but not hitting screen1viewbase?
