Shree
How to add custom display in TouchGFX ?
I am trying to interface 7"(ETM0700G0BDH6) display with STM32F769 custom board but I am not sure about below parameters:
1) What values should I fill in Layers setting in CubeMX
2) What values should I fill for DMA2D parameters
Can you please share some suggestions on how to calculate above values ?
Martin KJELDSEN
Principal III
August 12, 2020
I'd suggest taking a look at the F769 disco/eval application templates from the designer. They have an .ioc file you can open inside CubeMX and look at the LTDC/DSI setings.
/Martin
