NHo.1
How does TouchGFX write image to SDRAM?
Hi ST,
I am doing a project:
  • Use TouchGFX to generate image, link to SDRAM, MCU will get and show on LTDC (MIPI-DSI Interface). I don't know how does TouchGFX link to SDRAM.
  • How to build project touchGFX (MIPI-DSI interface)?
Thank you.
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
November 18, 2020
This is a very broad question. For your second point: Check out the DSI application templates from TouchGFX designer. The TouchGFX Generator in CubeMX only supports LTDC and custom display interface (LTDC = you get the driver for free, custom = you have to write it yourself).
For the first point: Not entirely sure what you mean here. But generally, a screen is rendered to the framebuffer (maybe SDRAM), and transferred to the display from here.
/Martin
Martin KJELDSEN
Principal III
November 18, 2020
/Martin
