Jack li1
How do I pause GFX when The screen is off??
  • July 3, 2020
  • 6 replies
  • 1563 views
I use the DSI screen and securely stop GFX when I close the screen。
eng23
Senior
July 3, 2020
I suspend TouchGFX task in RTOS:
osThreadSuspend(defaultTaskHandle);
I don't know if it is the best way, but it works.
Jack li1
Jack li1Author
I tried this method but it crashed
Martin KJELDSEN
Principal III
July 3, 2020
NVIC_DisableIRQ(LTDC_IRQn);
(For LTDC setup). This stops the "tick" and TouchGFX Engine will wait on a semaphore until the interrupt is enabled again.
Jack li1
Jack li1Author
Using this method results in programs executing only OSWrappers::signalVSync();.Semaphore is not executed, resulting in modle: tick () not being executed
Martin KJELDSEN
Principal III
July 7, 2020
​Correct :) That's "stopping" touchgfx in my mind. You want something else? Go into low power mode?
