HAnh
How can I Save and Get data from Model in touchGFX
Hi everyone.
I have built many screens, and in every screen I have many single data and array data.
About single data I can transfer them to other screen, by save them to model when I close screen.
But I don't know how to save Array data (like Time [10]) to model when I close screen and get them when I active scree.
So Anyone can give me some advice to solve my problem
Thanks and best regards.
Alexandre RENOUX
October 27, 2020
Please have a look at the following article on our documentation website : https://support.touchgfx.com/docs/tutorials/tutorial-03
This should help you.
/Alexandre
HAnh
HAnhAuthor
Hi Alexandre RENOUX.
I have read Tutorial-03,and can transfer data to another screen via model, but it only single data like uint_8, uint_16.
Everything I need, that is I can transfer Array data to another screens line Time[10], Date[30].
Because if I using single data, it very long and must using many single data.
So can you help me in this case.
Alexandre RENOUX
October 27, 2020
I see that you are not familiar with c and c++ programming. In these languages, you have something called pointers.
https://www.tutorialspoint.com/cplusplus/cpp_passing_arrays_to_functions.htm
/Alexandre
HAnh
HAnhAuthor
Yes, You right, I'm not familiar with c and c++ programming, thanks for your share.
But I don't know how to declare Array in the model.ccp like:
Model::Model() : modelListener(0), hour(0), minute(0)
in my know, hour(0) and minute(0) is single variable, but now I need declare Array in this that.
I tried to declared as bellow:
Model::Model() : modelListener(0), Array1[10],*Array2
But is don't correct.
Can you show me, how to declare Array in this case.
Thanks you so much.
Alexandre RENOUX
October 30, 2020
Simply write in Model.hpp
int array1[10];
I don't know if you are trying to use int or not but just put whatever type you need.
This forum is not meant to teach people how to code in c or c++. Please look on the internet for how to declare arrays, what's a a class, a constructor, ...etc
/Alexandre
HAnh
HAnhAuthor
Hi.
Maybe you don't read my question carefully.
I asked that how to declare Array in the model.ccp like some single variable like:
Absolutely before that I must declared in model.hpp:
int array1[10];
In my know, hour(0) and minute(0) make initiate value for hour and minute variable, but now I need declare Array in this that.
Alexandre RENOUX
November 2, 2020
My bad.
If you want to initiate the values, simply do it inside the brackets
 // Do it here but here is an example
 for(int i = 0; i < 10; i++)
 array1[i] = 0;
/Alexandre
