How can I resize the "circle progress" from TouchGFX Designer or even after generating the code from the designer ???
I tried to modify the ViewBase file generated by the designer by adjusting the width and height of the circle progress but nothing happened and I could not resize this element at all. So Is there is any other method to have different sizes of the circle progress either before generating the code from the designer or even after generating it by modifying some other code ???
