How can I make software video decoding faster?
I'm using software decoding with double buffer strategy, but the decoding takes too long (about 50ms per frame).
I tried to change the video frame rate to 10fps, but for a video of size 216x530 with a length of 30 seconds, the video output length is about a minute.
I also tried to lower the quality of the video to no avail.
1) Would lowering the video format work? and what should I lower it to? (I have VIDEO_DECODE_FORMAT = RGB565)
2) Should I try a different software decoder? (and where can I get it?)
Thanks!
