MTora.1
Jan 5, 2023 2:37 PM UTC
How can I have several external sections?
Hi dears
How can I have several external sections in cuneIDE?
0693W00000Y7V5lQAF.pngand how can learn to touchGFX that separates Images?
for example, 3 images place in ExtSection1 and the rest in ExtSection2.
 0693W00000Y7V7IQAV.png here we have only two sections.
MM..1
Jan 5, 2023 2:58 PM UTC
I mean in designer now cant, but you can define all this in linker script.
MTora.1
MTora.1Author
Jan 5, 2023 3:13 PM UTC
I will make two sections in the linker script.
So, what about code? how can I categorize them?
after categorization, does the simulator still work?
MM..1
Jan 5, 2023 4:28 PM UTC
In code you do nothink if files to place have own object files.
Images is generated as separate object files then in linker you can place it as you choice.
