VKost.3
Jan 17, 2022 5:49 AM UTC
how can i change text color in custom container from view, custom container is used in scroll wheel
    MM..1
    Jan 17, 2022 1:06 PM UTC
    You need create method for this in custom container class and use it...
    VKost.3
    VKost.3Author
    Jan 18, 2022 2:15 AM UTC
    i created a method in a custom container. I have a hardware button and want to call a container method when it is clicked. How can I do that?
    MM..1
    Jan 18, 2022 1:08 PM UTC
    In lists is little complicated but basic code is
    scrollList1ListItems[cursorpos].yourcustomsetcolor(1234);
    this is code in screen func and this need be called from hw button check... for example in screenhandletick
    VKost.3
    VKost.3Author
    Mar 26, 2022 6:01 AM UTC
    scrollWheelListItems[containerIndex].yourcustomsetcolor(1234);
    How to find the container index?
    I have the following settings:
    scrollWheel.setNumberOfItems(100);
    touchgfx::DrawableListItems<ChannelContainer, 2> scrollWheelListItems;
