Jul 22, 2024 11:57 AM UTC
highlight scroll wheel selected icon
hi,
I have a scroll wheel with 7 icons, with a circular appearance.
I'd like to enlarge a bit the selected item, to make clear that item has been selected, is it possible? can touchgfx resize the selected icon?
Thanks in advance
LouisBBest answer
Jul 23, 2024 10:23 AM UTC
Hello @ab73 ,
The simplest way is to tick the Use Selected Style Template
Then you will need a second set of custom container for selected item.
BR,
Louis BOUDOST Software Engineer | TouchGFX
LouisBBest answer
Hello @ab73 ,
BR,
ab73Author
Jul 24, 2024 6:15 AM UTC
so I need a second set of enlarged icons to use in a second container?
and a user code similar to the main container to change the shown icon?
EDIT:
it works, thanks
Sep 26, 2024 1:57 PM UTC
Hello @ab73 ,
Yes you need a second set of items that you will specify in selected style Template.
BR,
