ACost.1100
Hey everyone! i am trying to run any template program from touchGFX on the STM32F7691-Discovery but this error message shows up on the log file:
 make -f ../gcc/Makefile -j8 flash
    Converting images
    Linking TouchGFX/build/bin/target.elf
    Producing additional output formats...
     target.hex  - Combined internal+external hex
     intflash.elf - Internal flash, elf debug
     intflash.hex - Internal flash, hex
     extflash.bin - External flash, binary
    /usr/bin/sh: C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe: No such file or directory
    gcc/Makefile:320: recipe for target '_extflash_' failed
    make[1]: *** [_extflash_] Error 127
    ../gcc/Makefile:48: recipe for target 'flash' failed
    make: *** [flash] Error 2
    Failed
  Failed
November 12, 2019
Perhaps install the ST-LINK Utilities if you haven't done so already.
If you have check the file paths where it is installed, and correct the make file appropriately to reflect where they are.
https://www.st.com/en/development-tools/stsw-link004.html
ACost.1100
thanks !:grinning_face:
got it working!
