Apr 19, 2025 5:35 PM UTC
Help with Slide Menu
Hi there,
I'm new to STM32 and was successful to setup a 800x480 LCD with a STM32H743 and SDRAM as Framebuffer.
Now I'm stuck with desiging the GUI with TouchGFX. I would like to add the Slide Menu Option to my screen, however when I press on the assigned button nothing happens in the simulator. I looked at the Slide Menu example but I can't see a difference to my setup. Could someone also have a look at my configuration?
    MM..1
    Apr 20, 2025 7:50 AM UTC
    Seems cant work without background image defined...
    Apr 20, 2025 11:58 AM UTC
    Thanks for the Input, now the defined background slides in, however the buttons don't appear. It seems they are covered by the background?
    My configuration now looks like this:
    I marked the slide Menu with my cursor.
    Any help would be appreciated.
    GaetanGodart
    Apr 23, 2025 1:55 PM UTC
    Hello @always_energized ,
    Can you please share your full project as a 7z file (zipped file)?
    Regards,
    Gaetan GodartSoftware engineer at ST (TouchGFX)
