Celebriums
Hello I set up TouchGFX and when I want to simulate, I get an error like the following. It doesn't work on Code Generator and Run Target.
Run Simulator
  Copy Framework
    Copying TouchGFX framework version 4.13.0 to C:\TouchGFXProjects\MyApplication\Middlewares\ST\touchgfx
    Done
  Generate
    Wrote config/gcc/app.mk
    Wrote config/msvs/Application.props
    Wrote generated/gui_generated/include/gui_generated/common/FrontendApplicationBase.hpp
    Wrote generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp
    Wrote generated/gui_generated/include/gui_generated/common/SimConstants.hpp
    Wrote generated/gui_generated/include/gui_generated/main_screen/MainViewBase.hpp
    Wrote generated/gui_generated/src/common/FrontendApplicationBase.cpp
    Wrote generated/gui_generated/src/main_screen/MainViewBase.cpp
    Wrote generated/simulator/gcc/Makefile
    Wrote generated/simulator/include/simulator/mainBase.hpp
    Wrote generated/simulator/msvs/touchgfx.props
    Wrote generated/simulator/msvs/touchgfx_prebuild.targets
    Wrote generated/simulator/msvs/touchgfx_sdl2.props
    Wrote generated/simulator/src/mainBase.cpp
    Wrote generated/simulator/touchgfx.ico
    Wrote generated/simulator/touchgfx.rc
    Wrote generated/simulator/touchgfx.res
    Wrote simulator/gcc/Makefile
    Wrote simulator/main.cpp
    Wrote simulator/msvs/Application.sln
    Wrote simulator/msvs/Application.vcxproj
    Wrote simulator/msvs/Application.vcxproj.filters
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j8
    Writing generated/images/src/bg.cpp
    Writing generated/images/src/radio_button_selected.cpp
    Writing generated/images/src/radio_button_selected_pressed.cpp
    Writing generated/images/src/radio_button_unselected.cpp
    Writing generated/images/src/radio_button_unselected_pressed.cpp
    Writing generated/images/include/BitmapDatabase.hpp
    Writing generated/images/src/BitmapDatabase.cpp
    "\x8D" to UTF-8 in conversion from Windows-1254 to UTF-8
    an error occurred in converting texts:
    make[1]: *** [texts] Error 1
    Cleaning generated files from generated/texts and generated/fonts.
    generated/simulator/gcc/Makefile:219: recipe for target 'texts' failed
    simulator/gcc/Makefile:32: recipe for target 'assets' failed
    make: *** [assets] Error 2
    Failed
  Failed
Alexandre RENOUX
June 16, 2020
From what I can see, it looks like you have a conversion issue. This is the following debug lines that are important :
What kind of text do you want to display ?
First try to remove the TextArea (if it is one) you are using and see if you still have the error.
Please when you create a post for one of your issues, give some background on what you are doing such as what kind of GUI you are trying to make, (if any) what board are you using, what version of TouchGFX, etc. This will help us answering you more accurately.
/Alexandre
Celebriums
I'm using TouchGFX 4.13.0 versiyon and STM769I-DISCO board .
I have previously tested the following states for simulation and the error is the same.
1. There are 1 button in the sample.
2. There are no items in the example. I opened the example of Blank UI.
3. There are any examples prepared in the sample.
Celebriums
I just started the program, and I couldn't get it to work.
https://support.touchgfx.com/docs/introduction/installation/#installing-touchgfx-generator-in-cubemx
STMCubeMX
STMProgramming
STlink is very working.
I set up the program on the link below.
I know my brother's Laptop works smoothly.
Alexandre RENOUX
June 17, 2020
To be on the same page, can you do the following steps ?
  1. Open TouchGFX Designer 4.13.0
  2. Choose the Application Template for STM32F769-DISCO
  3. Choose Blank GUI
  4. Add a box as the background and a button on the screen
  5. Click on "Generate Code"
  6. Click on "Run Target" (make sure your board is connected to your laptop)
  7. Can you tell me what error do you encounter (if any) at this stage ?
/Alexandre
Celebriums
Dear Alexandre
The error code never changes. I couldn't get through that part.
5. Generate Code
  Generate
    Wrote generated/gui_generated/include/gui_generated/screen1_screen/Screen1ViewBase.hpp
    Wrote generated/gui_generated/src/screen1_screen/Screen1ViewBase.cpp
    Done
  Generate Assets
    Writing generated/images/src/__designer/Blue_Buttons_Round_Edge_small.cpp
    Writing generated/images/src/__designer/Blue_Buttons_Round_Edge_small_pressed.cpp
    Writing generated/images/src/__designer/Blue_Textures_church.cpp
    Failed
  Failed
6. Run Target
Run Target
  Generate
    Done
  Generate Assets
    Failed
  Failed
/Sadık
Celebriums
I found the problem, and I solved it.
Windows username is Turkish.
The letter "Sad"ı"k" in The Sadık Sume.
Here's the solution.
1- I removed all STM programs from remove my computer.
2- I've added a new user in Windows 10.
3- I made the username STM32. (English must have characters.)
4- TouchGFX, STM32CubeMX 5.6, ST link programs i installed and successfully run.
