LMalv.1
Hello, I'm new with TouchGFX, I would like to use an Application template with a different display resolution and size.
searching on Internet I found the solution, that is to create a custom application template, but the link, https://touchgfx.zendesk.com/hc/en-us/articles/115002741432-Create-custom-Application-Template It still not available, so I'm looking for a new link with detailed documentation for create my custom application template
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
April 28, 2020
Hi @LMalv.1​,
Also check out https://support.touchgfx.com/docs/development/touchgfx-hal-development/scenarios/scenarios-change-pixelformat-bpp
It shows what to consider when wanting to make changes to a TouchGFX project by reconfiguring the CubeMX project (like resolution, bit depth),
And the article for creating an application template is here: https://support.touchgfx.com/docs/development/touchgfx-hal-development/scenarios/scenarios-create-at
/Martin
Romain DIELEMAN
Hi, please have a look at the Board Bring Up section in the new documentation. The How To sub section will guide you through the configuration steps to create your own application template for a custom board. This might be complicated and take you some time if you are new to this.
/Romain
Martin KJELDSEN
Principal III
April 28, 2020
Hi @LMalv.1​,
/Martin
pabian
Hi Martin,
In the article for creating an application template,
" Open a TouchGFX Environment console and execute the following command in the parent directory of the application:"
  • What is the touchGFX Environment console?
  • How I open it?
pabian
I solved.
  • open PowerShell in Windows
  • move to the TouchGFX project folder location (C:\TouchGFXProjects\Myapplication created from TouchGFX desinger)
  • call ​<tgfx.exe directoy path>\tgfx.exe -d MyApplication (*MyApplication.touchgfx file must be in the MyApplication folder)
  • created MyApplication.zip and MyApplication.json
Everything is strange to a newbie.
LMalv.1
LMalv.1Author
Thank you !!!
