LucaCMA
Hello, I can't open my TouchGFX project. The message that appears is the following "reference to an object not set on an object instance" Can you help me? Regards, Luca
Martin KJELDSEN
Principal III
December 11, 2019
I need way more information than that :) Version? What've you tried? Share your project?
LucaCMA
LucaCMAAuthor
Hi Martin,
TouchGFX Designer Version 4.12.3
SLA0044 Rev5/February 2018
LucaCMA
LucaCMAAuthor
Sorry....correct project
LucaCMA
LucaCMAAuthor
do you have an idea for this problem?
Regards,
Martin KJELDSEN
Principal III
January 7, 2020
Hi Luca,
4.13.0 will be out this week so let's see if that solves things for you. I'm pretty sure we've fixed an issue similar to what you're seeing here.
/Martin
Sjohn.1
January 8, 2020
Hi, I have simillar issue with Cubemx 5.5.0 and TouchGFX 4.13.0
error msg : "Object reference not set to an instance of an object."
Martin KJELDSEN
Principal III
January 8, 2020
Are you trying to open up a possibly broken project in 4.13.0 ? Please show me a log for 4.13.0.
Kelsey
January 23, 2020
Is there a solution for this? I am having the same problem in my project. I was trying to upgrade my project from 4.12.3 to 4.13 and ran into this error. I can message the zip of my project if necessary.
LucaCMA
LucaCMAAuthor
I still have the same problem with 4.13
Martin KJELDSEN
Principal III
January 23, 2020
Sure, send your projects - I'll try to take a look at them. Will go have a chat with designer guys right now on the general error.
One thing that comes to mind is trying to open the excel sheet in assets/texts and seeing if Excel complains about any issues (if yes, click yes to fix).
/Martin
