KM L.1
Jul 20, 2020 8:01 AM UTC
Hardware integration for qwerty keypad
KM L.1
KM L.1Author
Jul 20, 2020 8:02 AM UTC
I want to know how to make qwerty keypad to react to the hardware button.. please anyone support me ​
Alexandre RENOUX
Jul 20, 2020 9:25 AM UTC
Could you be more precise ?
You want to be able to type on a qwerty keyboard and what you write is displayed on the screen right ?
But what board are you using ? You want to plug a qwerty keyboard to your board ?
You can look at this documentation page as a start : https://support.touchgfx.com/docs/development/board-bring-up/example-gpio
Please provide more information.
/Alexandre
KM L.1
KM L.1Author
Jul 20, 2020 9:47 AM UTC
Yes I'm able to type on qwerty keyboard with touch and its displaying on the screen.
As a start I went through that document also and I also integrated the physical button, now I am not getting how to make qwerty keyboard to react to the hardware button as i want to operate the qwerty keyboard using joystick buttons not with touch.
STM32H743I-eval board we are using.
KM L.1
KM L.1Author
Jul 20, 2020 9:49 AM UTC
I'm not getting the logic to make qwerty keypad to react to those buttons.......
Using those buttons I wanted to type on the qwerty keyboard and need to display that.
Alexandre RENOUX
Jul 20, 2020 11:09 AM UTC
You will find examples available at this page. It will show you how to propagate the buttonController data to the GUI and use it.
https://support.touchgfx.com/docs/development/ui-development/touchgfx-engine-features/backend-communication#from-gui-task
/Alexandre
KM L.1
KM L.1Author
Jul 20, 2020 11:22 AM UTC
I already went through this and also I have created tasks and hardware button is working fine.
But help me to operate qwerty keyboard using buttons.
KM L.1
KM L.1Author
Jul 20, 2020 11:37 AM UTC
I have written like this
KM L.1
KM L.1Author
Jul 20, 2020 11:38 AM UTC
uint8_t msg = 0;
if (xQueueReceive(gui_msg_q, &msg, 0) == pdTRUE)
  // Queue is used as a flag, so don't check msg.
  // Full = PRESSED, Empty = Do nothing.
   btnPressed();
#endif
KM L.1
KM L.1Author
Jul 20, 2020 11:39 AM UTC
void MainView::getBuffer() // add
how to use the custom keyboard function over here to operate using button
KM L.1
KM L.1Author
Jul 20, 2020 11:43 AM UTC
Actually Martin had told me to work on the physical button first then he is going to help me out , how to react to the custom keyboard
Alexandre RENOUX
Jul 21, 2020 7:59 AM UTC
You will find enclosed a quick implementation of the keyboard using buttons.
I haven't tested it with the actual board but the simulator is working. To link each physical button to a certain value, you should create a ButtonController class as follows (also explained in the documentation) :
class CustomButtonController : public touchgfx::ButtonController
 virtual void init() { previousState = JOY_NONE; }
 virtual bool sample(uint8_t& key)
 JOYState_TypeDef state = BSP_JOY_GetState();
 if (state == previousState)
 return false;
 previousState = state;
 switch(state)
 case JOY_SEL:
 key = '5';
 return true;
 case JOY_DOWN:
 key = '2';
 return true;
 case JOY_UP:
 key = '8';
 return true;
 case JOY_LEFT:
 key = '4';
 return true;
 case JOY_RIGHT:
 key = '6';
 return true;
 return false;
private:
 JOYState_TypeDef previousState;
Here are the keys used for the keyboard (you can change the code as you like) :
  • '5' select the highlighted key and print the corresponding letter
  • '6' and '4' are used to navigate among the different keys
  • '8' allows you to select capslock, numbers/special characters and delete.
You will find the main function making what you want possible void KeyboardJoystick::externalKeyPressed(uint8_t c) in KeyboardJoystick.cpp (gui\src\common\KeyboardJoystick.cpp)
/Alexandre
