Nov 5, 2024 11:25 PM UTC
hard fault after touchgfx::muldivu() called
I am working on STM32F426 with TouchGFX. However, after I upgrade STM32CUBEIDE and TouchGFX to latest version, I got a hard fault error. In the stack information, it shows the hard fault happens after touchgfx::muldivu() called.
And in the fault analyzer, the fault is to attempt to perform a division by zero.
May I know if there is any way to solve it? Thanks.
Edit : fixed it
Andrew Neil
Nov 6, 2024 12:54 AM UTC
Would be more helpful to describe what was the problem and how you fixed it - then anyone searching in the future could find it.
GaetanGodart
Nov 7, 2024 3:33 PM UTC
Hello @hbZhao ,
Indeed, it would be nice if you could briefly explain the issue you had and how you solved it! :smiling_face_with_smiling_eyes:
I have reverted your message to the original (before edit) so you don't have to rewrite it).
Regards,
Gaetan GodartSoftware engineer at ST (TouchGFX)
Andrew Neil
Nov 7, 2024 3:40 PM UTC
Don't attempt to divide by zero!
Nov 7, 2024 4:25 PM UTC
100% this..
And perhaps CHECK if this is a posibility, and perhaps use a number for the solution which isn't unrepresentable?
