slawek
Mar 24, 2020 3:38 PM UTC
handleDragEvent on specific object only
Is there a possibility to handle events which are in specific area, i.e. I would like to know when and how user drags over texture mapper area to rotate it accordingly.
Thank You,
Sławek
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Mar 31, 2020 2:38 PM UTC
You can override the handleDragEvent function for your view and check if the coordinates intersect with various elements on screen. Here's some pseudocode
void MyView::handleDragEvent(const DragEvent& evt)
 int16_t newX = evt.getNewX();
 int16_t newY = evt.getNewY();
 //Check for intersection
 if(intersects)
 element.handleDragEvent(evt);
Martin KJELDSEN
Principal III
 if(intersects)
