x893-00
HAL_DSI_MspInit bad generation for STM32H747
i use DSI Host with generation in separate file dsihost.c
In HAL_DSI_MspInit CubeMX and STM32IDE generate next lines
/* DSI clock enable */
__HAL_RCC_DSI_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
error: expected expression before ')' token
ChahinezC
Hello @x893-00​,
Can you precise which STM32CubeMX, CubeH7 package versions you are using?
Can you also share your ioc file? This will help us check the problem.
Chahinez.
x893-00
x893-00Author
stm32cube_fw_h7_v190.zip
CubeMX 6.2.1
STM32IDE 1.6.1
ChahinezC
Hi @x893-00​,
I checked your file and generated the project but I couldn't reproduce the same behavior from my side.
Chahinez.
x893-00
x893-00Author
looks strange. I open H747XIH.ioc in CubeMX, click GENERATE CODE and see line 174 in file
CM7\Core\Src\dsihost.c
 /**DSIHOST GPIO Configuration
