TKim.11
Aug 30, 2019 10:14 AM UTC
getting stuck in HardFault_Handler() if I add Scalable image.
Hello.
I have a question about the TouchGFX - scalable image.
I succeeded to see the screen of TouchGFX.
Here is my hardware:
  1. STM32F429IGT6.
  2. 800 * 480 TFT LCD
  3. 16Mbit SDRAM
I could see some of simple touchgfx gui.
But If I add "scalable image", It is stuck in HardFault_Handler().
I used an png image and it's size is about 24 Kbyte.
I cannot find any reason for this problem.
Can you help about this problem??
Regards,
Patrick.
Martin KJELDSEN
Principal III
Sep 2, 2019 7:42 AM UTC
Hi @TKim.11​,
Is this only if you add a scaleable image? What about other types of widgets?
/Martin
TKim.11
TKim.11Author
Sep 6, 2019 12:47 AM UTC
Hi Martin,
Thanks for your reply.
The scalable image is the only one that I added to screen.
Martin KJELDSEN
Principal III
Sep 6, 2019 6:37 AM UTC
There are no additional memory requirements. Try increasing the stack size of your UI Task. Did you do any debugging on this?
/Martin
